LLST: Location Lost
This message is generated whenever a location for an object copy (replicated or erasure-coded) can't be found.
| Code | Field | Description |
CBIL  |
CBID  |
The affected CBID.  |
ECPR  |
Erasure-Coding Profile  |
For erasure-coded object data. The ID of the erasure-coding profile used.  |
LTYP  |
Location Type  |
CLDI (Online): For replicated object data CLEC (Online): For erasure-coded object data CLNL (Nearline): For archived replicated object data  |
NOID  |
Source Node ID  |
The node ID on which the locations were lost.  |
PCLD  |
Path to replicated object  |
The complete path to the disk location of the lost object data. Only returned when LTYP has a value of CLDI (that is, for replicated objects). Takes the form   |
RSLT  |
Result  |
Always NONE. RSLT is a mandatory message field, but is not relevant for this message. NONE is used rather than SUCS so that this message is not filtered.  |
TSRC  |
Triggering Source  |
USER: User triggered SYST: System triggered  |
UUID  |
Universally Unique ID  |
The identifier of the affected object in the StorageGRID system.  |
