System audit messages
The audit messages belonging to the system audit category are used for events related to the auditing system itself, grid node states, system-wide task activity (grid tasks), and service backup operations.
| Code | Message title and description | See |
ECMC |
Missing Erasure Coded Data Fragment: Indicates that a missing erasure coded data fragment has been detected. |
ECOC |
Corrupt Erasure Coded Data Fragment: Indicates that a corrupt erasure coded data fragment has been detected. |
ETAF |
Security Authentication Failed: A connection attempt using Transport Layer Security (TLS) failed. |
GNRG |
GNDS Registration: A service updated or registered information about itself in the StorageGRID system. |
GNUR |
GNDS Unregistration: A service has unregistered itself from the StorageGRID system. |
GTED |
Grid Task Ended: The CMN service finished processing the grid task. |
GTST |
Grid Task Started: The CMN service started to process the grid task. |
GTSU |
Grid Task Submitted: A grid task was submitted to the CMN service. |
LLST |
Location Lost: This audit message is generated when a location is lost. |
OLST |
Object Lost: A requested object cannot be located within the StorageGRID system. |
SADD |
Security Audit Disable: Audit message logging was turned off. |
SADE |
Security Audit Enable: Audit message logging has been restored. |
SVRF |
Object Store Verify Fail: A content block failed verification checks. |
SVRU |
Object Store Verify Unknown: Unexpected object data detected in the object store. |
SYSD |
Node Stop: A shutdown was requested. |
SYST |
Node Stopping: A service initiated a graceful stop. |
SYSU |
Node Start: A service started; the nature of the previous shutdown is indicated in the message. |
