      ECMC: Missing Erasure Coded Data Fragment
This audit message indicates that the system has detected a missing erasure-coded data fragment.
| Code | Field | Description |
VCMC  |
VCS ID  |
The name of the VCS that contains the missing chunk.  |
MCID  |
Chunk ID  |
The identifier of the missing erasure-coded fragment.  |
RSLT  |
Result  |
This field has the value 'NONE'. RSLT is a mandatory message field, but is not relevant for this particular message. 'NONE' is used rather than 'SUCS' so that this message is not filtered.  |
