ECMC audit message for missing erasure-coded data in StorageGRID
This audit message indicates that the system has detected a missing erasure-coded data fragment.
| Code | Field | Description |
VCMC |
VCS ID |
The name of the VCS that contains the missing chunk. |
MCID |
Chunk ID |
The identifier of the missing erasure-coded fragment. |
RSLT |
Result |
This field has the value 'NONE'. RSLT is a mandatory message field, but is not relevant for this particular message. 'NONE' is used rather than 'SUCS' so that this message is not filtered. |
