Audit messages for system events in StorageGRID
The audit messages belonging to the system audit category are used for events related to the auditing system itself, grid node states, system-wide task activity (grid tasks), and service backup operations.
Code Message title and description See
ECMC
Missing Erasure-Coded Data Fragment: Indicates that a missing erasure-coded data fragment has been detected.
ECOC
Corrupt Erasure-Coded Data Fragment: Indicates that a corrupt erasure-coded data fragment has been detected.
ETAF
Security Authentication Failed: A connection attempt using Transport Layer Security (TLS) failed.
GNRG
GNDS Registration: A service updated or registered information about itself in the StorageGRID system.
GNUR
GNDS Unregistration: A service has unregistered itself from the StorageGRID system.
GTED
Grid Task Ended: The CMN service finished processing the grid task.
GTST
Grid Task Started: The CMN service started to process the grid task.
GTSU
Grid Task Submitted: A grid task was submitted to the CMN service.
LLST
Location Lost: This audit message is generated when a location is lost.
OLST
Object Lost: A requested object cannot be located within the StorageGRID system.
SADD
Security Audit Disable: Audit message logging was turned off.
SADE
Security Audit Enable: Audit message logging has been restored.
SVRF
Object Store Verify Fail: A content block failed verification checks.
SVRU
Object Store Verify Unknown: Unexpected object data detected in the object store.
SYSD
Node Stop: A shutdown was requested.
SYST
Node Stopping: A service initiated a graceful stop.
SYSU
Node Start: A service started; the nature of the previous shutdown is indicated in the message.
