WPUT: Swift PUT
PDF of this doc site
Install and upgrade
Configure and manage
Maintain
Recover nodes and maintain your grid
Creating your file...
When a Swift client issues a PUT transaction, a request is made to create a new object or container. This message is issued by the server if the transaction is successful.
Code | Field | Description |
CBID |
Content Block Identifier |
The unique identifier of the content block requested. If the CBID is unknown, this field is set to 0. Operations on containers don't include this field. |
CSIZ |
Content Size |
The size of the retrieved object in bytes. Operations on containers don't include this field. |
HTRH |
HTTP Request Header |
List of logged HTTP request header names and values as selected during configuration.
MTME |
Last Modified Time |
The Unix timestamp, in microseconds, indicating when the object was last modified. |
RSLT |
Result Code |
Result of the PUT transaction. Result is always: SUCS: successful |
SAIP |
IP address of requesting client |
The IP address of the client application that made the request. |
TIME |
Time |
Total processing time for the request in microseconds. |
TLIP |
Trusted Load Balancer IP Address |
If the request was routed by a trusted Layer 7 load balancer, the IP address of the load balancer. |
UUID |
Universally Unique Identifier |
The identifier of the object within the StorageGRID system. |
WACC |
Swift Account ID |
The unique account ID as specified by the StorageGRID system. |
WCON |
Swift Container |
The Swift container name. |
WOBJ |
Swift Object |
The Swift object identifier. Operations on containers don't include this field. |
WUSR |
Swift Account User |
The Swift account username that uniquely identifies the client performing the transaction. |
