Use audit-sum tool
You can use the audit-sum tool to count the write, read, head, and delete audit messages and to see the minimum, maximum, and average time (or size) for each operation type.
You must have specific access permissions.
You must have the
Passwords.txtfile. -
You must know the IP address of the primary Admin Node.
The audit-sum tool, available on the primary Admin Node, summarizes how many write, read, and delete operations were logged and how long these operations took.
The audit-sum tool is primarily intended for use by technical support during troubleshooting operations. Processing audit-sum queries can consume a large amount of CPU power, which might impact StorageGRID operations.
This example shows typical output from the audit-sum tool. This example shows how long protocol operations took.
message group count min(sec) max(sec) average(sec) ============= ===== ======== ======== ============ IDEL 274 SDEL 213371 0.004 20.934 0.352 SGET 201906 0.010 1740.290 1.132 SHEA 22716 0.005 2.349 0.272 SPUT 1771398 0.011 1770.563 0.487
The audit-sum tool provides counts and times for the following S3, Swift, and ILM audit messages in an audit log:
| Code | Description | Refer to |
ARCT |
Archive Retrieve from Cloud-Tier |
ASCT |
Archive Store Cloud-Tier |
IDEL |
ILM Initiated Delete: Logs when ILM starts the process of deleting an object. |
SDEL |
S3 DELETE: Logs a successful transaction to delete an object or bucket. |
SGET |
S3 GET: Logs a successful transaction to retrieve an object or list the objects in a bucket. |
SHEA |
S3 HEAD: Logs a successful transaction to check for the existence of an object or bucket. |
SPUT |
S3 PUT: Logs a successful transaction to create a new object or bucket. |
WDEL |
Swift DELETE: Logs a successful transaction to delete an object or container. |
WGET |
Swift GET: Logs a successful transaction to retrieve an object or list the objects in a container. |
WHEA |
Swift HEAD: Logs a successful transaction to check for the existence of an object or container. |
WPUT |
Swift PUT: Logs a successful transaction to create a new object or container. |
The audit-sum tool can do the following:
Process plain or compressed audit logs. For example:
audit-sum audit.logaudit-sum 2019-08-12.txt.gz -
Process multiple files simultaneously. For example:
audit-sum audit.log 2019-08-12.txt.gz 2019-08-13.txt.gzaudit-sum /var/local/audit/export/* -
Accept input from a pipe, which allows you to filter and preprocess the input using the
grepcommand or other means. For example:grep WGET audit.log | audit-sumgrep bucket1 audit.log | audit-sumgrep SPUT audit.log | grep bucket1 | audit-sum
This tool does not accept compressed files as piped input. To process compressed files, provide their file names as command-line arguments, or use the
You can use command-line options to summarize operations on buckets separately from operations on objects or to group message summaries by bucket name, by time period, or by target type. By default, the summaries show the minimum, maximum, and average operation time, but you can use the size (-s) option to look at object size instead.
Use the help (-h) option to see the available options. For example:
$ audit-sum -h
Log in to the primary Admin Node:
Enter the following command:
ssh admin@primary_Admin_Node_IP -
Enter the password listed in the
Enter the following command to switch to root:
su - -
Passwords.txtfile.When you are logged in as root, the prompt changes from
$to#.
If you want to analyze all messages related to write, read, head, and delete operations, follow these steps:
Enter the following command, where
/var/local/audit/export/audit.logrepresents the name and the location of the file or files you want to analyze:$ audit-sum /var/local/audit/export/audit.logThis example shows typical output from the
audit-sumtool. This example shows how long protocol operations took.message group count min(sec) max(sec) average(sec) ============= ===== ======== ======== ============ IDEL 274 SDEL 213371 0.004 20.934 0.352 SGET 201906 0.010 1740.290 1.132 SHEA 22716 0.005 2.349 0.272 SPUT 1771398 0.011 1770.563 0.487
In this example, SGET (S3 GET) operations are the slowest on average at 1.13 seconds, but SGET and SPUT (S3 PUT) operations both show long worst-case times of about 1,770 seconds.
To show the slowest 10 retrieval operations, use the grep command to select only SGET messages and add the long output option (
-l) to include object paths:grep SGET audit.log | audit-sum -lThe results include the type (object or bucket) and path, which allows you to grep the audit log for other messages relating to these particular objects.
Total: 201906 operations Slowest: 1740.290 sec Average: 1.132 sec Fastest: 0.010 sec Slowest operations: time(usec) source ip type size(B) path ========== =============== ============ ============ ==== 1740289662 10.96.101.125 object 5663711385 backup/r9O1OaQ8JB-1566861764-4519.iso 1624414429 10.96.101.125 object 5375001556 backup/r9O1OaQ8JB-1566861764-6618.iso 1533143793 10.96.101.125 object 5183661466 backup/r9O1OaQ8JB-1566861764-4518.iso 70839 10.96.101.125 object 28338 bucket3/dat.1566861764-6619 68487 10.96.101.125 object 27890 bucket3/dat.1566861764-6615 67798 10.96.101.125 object 27671 bucket5/dat.1566861764-6617 67027 10.96.101.125 object 27230 bucket5/dat.1566861764-4517 60922 10.96.101.125 object 26118 bucket3/dat.1566861764-4520 35588 10.96.101.125 object 11311 bucket3/dat.1566861764-6616 23897 10.96.101.125 object 10692 bucket3/dat.1566861764-4516From this example output, you can see that the three slowest S3 GET requests were for objects about 5 GB in size, which is much larger than the other objects. The large size accounts for the slow worst-case retrieval times.
If you want to determine what sizes of objects are being ingested into and retrieved from your grid, use the size option (
-s):audit-sum -s audit.logmessage group count min(MB) max(MB) average(MB) ============= ===== ======== ======== ============ IDEL 274 0.004 5000.000 1654.502 SDEL 213371 0.000 10.504 1.695 SGET 201906 0.000 5000.000 14.920 SHEA 22716 0.001 10.504 2.967 SPUT 1771398 0.000 5000.000 2.495
In this example, the average object size for SPUT is under 2.5 MB, but the average size for SGET is much larger. The number of SPUT messages is much higher than the number of SGET messages, indicating that most objects are never retrieved.
If you want to determine if retrievals were slow yesterday:
Issue the command on the appropriate audit log and use the group-by-time option (
-gt), followed by the time period (for example, 15M, 1H, 10S):grep SGET audit.log | audit-sum -gt 1Hmessage group count min(sec) max(sec) average(sec) ============= ===== ======== ======== ============ 2019-09-05T00 7591 0.010 1481.867 1.254 2019-09-05T01 4173 0.011 1740.290 1.115 2019-09-05T02 20142 0.011 1274.961 1.562 2019-09-05T03 57591 0.010 1383.867 1.254 2019-09-05T04 124171 0.013 1740.290 1.405 2019-09-05T05 420182 0.021 1274.511 1.562 2019-09-05T06 1220371 0.015 6274.961 5.562 2019-09-05T07 527142 0.011 1974.228 2.002 2019-09-05T08 384173 0.012 1740.290 1.105 2019-09-05T09 27591 0.010 1481.867 1.354
These results show that S3 GET traffic spiked between 06:00 and 07:00. The max and average times are both considerably higher at these times as well, and they did not ramp up gradually as the count increased. This suggests that capacity was exceeded somewhere, perhaps in the network or in the grid's ability to process requests.
To determine what size objects were being retrieved each hour yesterday, add the size option (
-s) to the command:grep SGET audit.log | audit-sum -gt 1H -smessage group count min(B) max(B) average(B) ============= ===== ======== ======== ============ 2019-09-05T00 7591 0.040 1481.867 1.976 2019-09-05T01 4173 0.043 1740.290 2.062 2019-09-05T02 20142 0.083 1274.961 2.303 2019-09-05T03 57591 0.912 1383.867 1.182 2019-09-05T04 124171 0.730 1740.290 1.528 2019-09-05T05 420182 0.875 4274.511 2.398 2019-09-05T06 1220371 0.691 5663711385.961 51.328 2019-09-05T07 527142 0.130 1974.228 2.147 2019-09-05T08 384173 0.625 1740.290 1.878 2019-09-05T09 27591 0.689 1481.867 1.354
These results indicate that some very large retrievals occurred when the overall retrieval traffic was at its maximum.
To see more detail, use the audit-explain tool to review all the SGET operations during that hour:
grep 2019-09-05T06 audit.log | grep SGET | audit-explain | lessIf the output of the grep command is expected to be many lines, add the
lesscommand to show the contents of the audit log file one page (one screen) at a time.
If you want to determine if SPUT operations on buckets are slower than SPUT operations for objects:
Start by using the
-gooption, which groups messages for object and bucket operations separately:grep SPUT sample.log | audit-sum -gomessage group count min(sec) max(sec) average(sec) ============= ===== ======== ======== ============ SPUT.bucket 1 0.125 0.125 0.125 SPUT.object 12 0.025 1.019 0.236
The results show that SPUT operations for buckets have different performance characteristics than SPUT operations for objects.
To determine which buckets have the slowest SPUT operations, use the
-gboption, which groups messages by bucket:grep SPUT audit.log | audit-sum -gbmessage group count min(sec) max(sec) average(sec) ============= ===== ======== ======== ============ SPUT.cho-non-versioning 71943 0.046 1770.563 1.571 SPUT.cho-versioning 54277 0.047 1736.633 1.415 SPUT.cho-west-region 80615 0.040 55.557 1.329 SPUT.ldt002 1564563 0.011 51.569 0.361
To determine which buckets have the largest SPUT object size, use both the
-gband the-soptions:grep SPUT audit.log | audit-sum -gb -smessage group count min(B) max(B) average(B) ============= ===== ======== ======== ============ SPUT.cho-non-versioning 71943 2.097 5000.000 21.672 SPUT.cho-versioning 54277 2.097 5000.000 21.120 SPUT.cho-west-region 80615 2.097 800.000 14.433 SPUT.ldt002 1564563 0.000 999.972 0.352
