Change link configuration of SG6000-CN controller
You can change the Ethernet link configuration of the SG6000-CN controller. You can change the port bond mode, the network bond mode, and the link speed.
The appliance has been placed maintenance mode.
Options for changing the Ethernet link configuration of the SG6000-CN controller include:
Changing Port bond mode from Fixed to Aggregate, or from Aggregate to Fixed
Changing Network bond mode from Active-Backup to LACP, or from LACP to Active-Backup
Enabling or disabling VLAN tagging, or changing the value of a VLAN tag
Changing the link speed.
From the StorageGRID Appliance Installer, select Configure Networking > Link Configuration.
Make the desired changes to the link configuration.
For more information about the options, see Configure network links.
When you are satisfied with your selections, click Save.
You might lose your connection if you made changes to the network or link you are connected through. If you aren't reconnected within 1 minute, re-enter the URL for the StorageGRID Appliance Installer using one of the other IP addresses assigned to the appliance:
https://Appliance_Controller_IP:8443If you made changes to the VLAN settings, the subnet for the appliance might have changed. If you need to change the IP addresses for the appliance, follow the Configure IP addresses instructions.
Select Configure Networking > Ping Test from the menu.
Use the Ping Test tool to check connectivity to IP addresses on any networks that might have been affected by the link configuration changes you made in the link configuration changes step.
In addition to any other tests you choose to perform, confirm that you can ping the Grid Network IP address of the primary Admin Node, and the Grid Network IP address of at least one other Storage Node. If necessary, return to the link configuration changes step and correct any link configuration issues.
When you are satisfied that your link configuration changes are working and you have additional procedures to perform while the node is in maintenance mode, perform them now. When you are done, or if you experienced any failures and want to start over, select Advanced > Reboot Controller, and then select one of these options:
Select Reboot into StorageGRID
Select Reboot into Maintenance Mode to reboot the controller with the node remaining in maintenance mode. Select this option if you experienced any failures during the procedure and want to start over. After the node finishes rebooting into maintenance mode, restart from the appropriate step in the procedure that failed.
It can take up to 20 minutes for the appliance to reboot and rejoin the grid. To confirm that the reboot is complete and that the node has rejoined the grid, go back to the Grid Manager. The NODES page should display a normal status (green check mark icon
to the left of the node name) for the appliance node, indicating that no alerts are active and the node is connected to the grid.
