EBDL: Empty Bucket Delete
The ILM scanner deleted an object in a bucket that is deleting all objects (performing an empty bucket operation).
| Code | Field | Description |
CSIZ |
Object Size |
The size of the object in bytes. |
PATH |
S3 Bucket/Key |
The S3 bucket name and S3 key name. |
SEGC |
Container UUID |
UUID of the container for the segmented object. This value is available only if the object is segmented. |
UUID |
Universally Unique Identifier |
The identifier of the object within the StorageGRID system. |
RSLT |
Result of the delete operation |
The result of event, process, or transaction. If is not relevant for a message, NONE is used rather than SUCS so that the message is not accidentally filtered. |
