Internal grid node communications
Contributors netapp-pcelmer netapp-lhalbert netapp-madkat netapp-pcarriga netapp-perveilerk ssantho3
The StorageGRID internal firewall allows incoming connections to specific ports on the Grid Network. Connections are also accepted on ports defined by load balancer endpoints.
Note NetApp recommends that you enable Internet Control Message Protocol (ICMP) traffic between grid nodes. Allowing ICMP traffic can improve failover performance when a grid node can't be reached.
In addition to ICMP and the ports listed in the table, StorageGRID uses the Virtual Router Redundancy Protocol (VRRP). VRRP is an internet protocol that uses IP protocol number 112. StorageGRID uses VRRP in unicast mode only. VRRP is required only if high availability groups are configured.
Guidelines for Linux-based nodes
If enterprise networking policies restrict access to any of these ports, you can remap ports at deployment time using a deployment configuration parameter. For more information about port remapping and deployment configuration parameters, see:
Guidelines for VMware-based nodes
Configure the following ports only if you need to define firewall restrictions that are external to VMware networking.
If enterprise networking policies restrict access to any of these ports, you can remap ports when you deploy nodes using the VMware vSphere Web Client, or by using a configuration file setting when automating grid node deployment. For more information about port remapping and deployment configuration parameters, see Install VMware.
Guidelines for appliance nodes
If enterprise networking policies restrict access to any of these ports, you can remap ports using the StorageGRID Appliance Installer. See Optional: Remap network ports for appliance.
StorageGRID internal ports
Port TCP or UDP From To Details
22
TCP
Primary Admin Node
All nodes
For maintenance procedures, the primary Admin Node must be able to communicate with all other nodes using SSH on port 22. Allowing SSH traffic from other nodes is optional.
80
TCP
Appliances
Primary Admin Node
Used by StorageGRID appliances to communicate with the primary Admin Node to start the installation.
123
UDP
All nodes
All nodes
Network time protocol service. Every node synchronizes its time with every other node using NTP.
443
TCP
All nodes
Primary Admin Node
Used for communicating status to the primary Admin Node during installation and other maintenance procedures.
1055
TCP
All nodes
Primary Admin Node
Internal traffic for installation, expansion, recovery, and other maintenance procedures.
1139
TCP
Storage Nodes
Storage Nodes
Internal traffic between Storage Nodes.
1501
TCP
All nodes
Storage Nodes with ADC
Reporting, auditing, and configuration internal traffic.
1502
TCP
All nodes
Storage Nodes
S3- and Swift-related internal traffic.
1504
TCP
All nodes
Admin Nodes
NMS service reporting and configuration internal traffic.
1505
TCP
All nodes
Admin Nodes
AMS service internal traffic.
1506
TCP
All nodes
All nodes
Server status internal traffic.
1507
TCP
All nodes
Gateway Nodes
Load balancer internal traffic.
1508
TCP
All nodes
Primary Admin Node
Configuration management internal traffic.
1509
TCP
All nodes
Archive Nodes
Archive Node internal traffic.
1511
TCP
All nodes
Storage Nodes
Metadata internal traffic.
5353
UDP
All nodes
All nodes
Provides the multicast DNS (mDNS) service used for full-grid IP changes and for primary Admin Node discovery during installation, expansion, and recovery.
Note: Configuring this port is optional.
7001
TCP
Storage Nodes
Storage Nodes
Cassandra TLS inter-node cluster communication.
7443
TCP
All nodes
Primary Admin Node
Internal traffic for installation, expansion, recovery, other maintenance procedures, and error reporting.
8011
TCP
All nodes
Primary Admin Node
8443
TCP
Primary Admin Node
Appliance nodes
Internal traffic related to the maintenance mode procedure.
9042
TCP
Storage Nodes
Storage Nodes
Cassandra client port.
9999
TCP
All nodes
All nodes
Internal traffic for multiple services. Includes maintenance procedures, metrics, and networking updates.
10226
TCP
Storage Nodes
Primary Admin Node
Used by StorageGRID appliances for forwarding AutoSupport messages from E-Series SANtricity System Manager to the primary Admin Node.
10342
TCP
All nodes
Primary Admin Node
11139
TCP
Archive/Storage Nodes
Internal traffic between Storage Nodes and Archive Nodes.
18000
TCP
Admin/Storage Nodes
Account service internal traffic.
18001
TCP
Admin/Storage Nodes
Identity Federation internal traffic.
18002
TCP
Admin/Storage Nodes
Storage Nodes
Internal API traffic related to object protocols.
18003
TCP
Admin/Storage Nodes
Platform services internal traffic.
18017
TCP
Admin/Storage Nodes
Storage Nodes
Data Mover service internal traffic for Cloud Storage Pools.
18019
TCP
Storage Nodes
Storage Nodes
Chunk service internal traffic for erasure coding.
18082
TCP
Admin/Storage Nodes
Storage Nodes
S3-related internal traffic.
18083
TCP
All nodes
Storage Nodes
18086
TCP
All grid nodes
All Storage Nodes
Internal traffic related to LDR service.
18200
TCP
Admin/Storage Nodes
Storage Nodes
Additional statistics about client requests.
19000
TCP
Admin/Storage Nodes
Keystone service internal traffic.
Related information
External communications
