Manage alerts and alarms: Overview
The StorageGRID alert system is designed to inform you about operational issues that require your attention. The legacy alarm system is deprecated.
Alert system
The alert system is designed to be your primary tool for monitoring any issues that might occur in your StorageGRID system. The alert system provides an easy-to-use interface for detecting, evaluating, and resolving issues.
Alerts are triggered at specific severity levels when alert rule conditions evaluate as true. When an alert is triggered, the following actions occur:
An alert severity icon is shown on the dashboard in the Grid Manager, and the count of Current Alerts is incremented.
The alert is shown on the NODES summary page and on the NODES > node > Overview tab.
An email notification is sent, assuming you have configured an SMTP server and provided email addresses for the recipients.
An Simple Network Management Protocol (SNMP) notification is sent, assuming you have configured the StorageGRID SNMP agent.
Legacy alarm system
Like alerts, alarms are triggered at specific severity levels when attributes reach defined threshold values. However, unlike alerts, many alarms are triggered for events that you can safely ignore, which might result in an excessive number of email or SNMP notifications.
The alarm system is deprecated and will be removed in a future release. If you are still using legacy alarms, you should fully transition to the alert system as soon as possible. |
When an alarm is triggered, the following actions occur:
The alarm appears on the SUPPORT > Alarms (legacy) > Current alarms page.
An email notification is sent, assuming you have configured an SMTP server and configured one or more mailing lists.
An SNMP notification might be sent, assuming you have configured the StorageGRID SNMP agent. (SNMP notifications aren't sent for all alarms or alarm severities.)
