Replace hardware components in storage controller shelf
If a hardware problem occurs, you might need to replace a component in the storage controller shelf.
You have the E-Series hardware replacement procedure.
You have physically located the storage appliance where you are replacing storage shelf hardware components in the data center.
To replace the battery in the storage controller, see the steps in the instructions for replacing a storage controller. Those instructions describe how to remove a controller from the appliance, remove the battery from the controller, install the battery, and replace the controller.
For instructions for the other field replaceable units (FRUs) in the controller shelves, access the E-Series procedures for system maintenance.
| FRU | See instructions |
Battery |
StorageGRID (these instructions): Replacing a storage controller |
Drive |
E-Series:
Power canister |
E-Series
Fan canister (60-drive shelves only) |
E-Series: Replace fan canister (60-drive) |
Drive drawer (60-drive shelves only) |
E-Series: Replace drive drawer (60-drive) |
After replacing the part, return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return & Replacements page for further information.
