Identify the primary Admin Node
The primary Admin Node hosts the CMN service. Some maintenance procedures can only be performed using the primary Admin Node.
Before you begin
You are signed in to the Grid Manager using a supported web browser.
You have specific access permissions.
Steps
Select SUPPORT > Tools > Grid topology.
Select site > Admin Node, and then select
to expand the topology tree and show the services hosted on this Admin Node.The primary Admin Node hosts the CMN service.
If this Admin Node does not host the CMN service, check the other Admin Nodes.
