Identify the primary Admin Node in StorageGRID
The primary Admin Node provides more functionality than non-primary Admin Nodes. For example, some maintenance procedures must be performed using the primary Admin Node.
For more information about Admin Nodes, see What is an Admin Node.
Before you begin
Steps
  1. Select Nodes.
  2. Enter primary in the search box.
    In the search results, identify the node with "Primary Admin Node" displayed in the Type column. One primary Admin Node should be listed.
