The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Identify the primary Admin Node
PDF of this doc site
Install, upgrade, and hotfix
Configure and manage
Creating your file...
Your file is ready
The primary Admin Node hosts the CMN service. Some maintenance procedures can only be performed using the primary Admin Node.
Before you begin
You are signed in to the Grid Manager using a supported web browser.
You have specific access permissions.
Steps
Select SUPPORT > Tools > Grid topology.
Select site > Admin Node, and then select
to expand the topology tree and show the services hosted on this Admin Node.
If this Admin Node does not host the CMN service, check the other Admin Nodes.
