SPOS: S3 POST
When an S3 client issues a POST Object request, this message is issued by the server if the transaction is successful.
| Code | Field | Description |
CBID |
Content Block Identifier |
The unique identifier of the content block requested. If the CBID is unknown, this field is set to 0. |
CNCH |
Consistency Control Header |
The value of the Consistency-Control HTTP request header, if present in the request. |
CNID |
Connection Identifier |
The unique system identifier for the TCP/IP connection. |
CSIZ |
Content Size |
The size of the retrieved object in bytes. |
HTRH |
HTTP Request Header |
List of logged HTTP request header names and values as selected during configuration.
(Not expected for SPOS). |
RSLT |
Result Code |
Result of the RestoreObject request. Result is always: SUCS: Successful |
S3AI |
S3 tenant account ID (request sender) |
The tenant account ID of the user who sent the request. An empty value indicates anonymous access. |
S3AK |
S3 Access Key ID (request sender) |
The hashed S3 access key ID for the user that sent the request. An empty value indicates anonymous access. |
S3BK |
S3 Bucket |
The S3 bucket name. |
S3KY |
S3 Key |
The S3 key name, not including the bucket name. Operations on buckets don't include this field. |
S3SR |
S3 Subresource |
The bucket or object subresource being operated on, if applicable. Set to "select" for an S3 Select operation. |
SACC |
S3 tenant account name (request sender) |
The name of the tenant account for the user who sent the request. Empty for anonymous requests. |
SAIP |
IP address (request sender) |
The IP address of the client application that made the request. |
SBAC |
S3 tenant account name (bucket owner) |
The tenant account name for the bucket owner. Used to identify cross-account or anonymous access. |
SBAI |
S3 tenant account ID (bucket owner) |
The tenant account ID of the owner of the target bucket. Used to identify cross-account or anonymous access. |
SRCF |
Subresource Configuration |
Restore information. |
SUSR |
S3 User URN (request sender) |
The tenant account ID and the user name of the user making the request. The user can either be a local user or an LDAP user. For example: Empty for anonymous requests. |
TIME |
Time |
Total processing time for the request in microseconds. |
TLIP |
Trusted Load Balancer IP Address |
If the request was routed by a trusted Layer 7 load balancer, the IP address of the load balancer. |
UUID |
Universally Unique Identifier |
The identifier of the object within the StorageGRID system. |
VSID |
Version ID |
The version ID of the specific version of an object that was requested. Operations on buckets and objects in unversioned buckets don't include this field. |
