      Remove a storage pool
You can remove a storage pool that is not being used.
Before you begin
You are signed in to the Grid Manager using a supported web browser.
You have the required access permissions.
Steps
Select ILM > Storage pools.
Look at the ILM usage column in the table to determine whether you can remove the storage pool.
You can't remove a storage pool if it is being used in an ILM rule or in an erasure-coding profile. As required, select storage pool name > ILM usage to determine where the storage pool is used.
If the storage pool you want to remove is not being used, select the checkbox.
Select Remove.
Select OK.
