Remove a storage pool
You can remove a storage pool that is not being used.
What you'll need
You are signed in to the Grid Manager using a supported web browser.
You have specific access permissions.
Steps
Select ILM > Storage pools.
The Storage Pools page appears.
Look at the ILM Usage column in the table to determine whether you can remove the storage pool.
You cannot remove a storage pool if it is being used in an ILM rule or in an Erasure Coding profile. As required, select View Details > ILM Usage to determine where a storage pool is used.
If the storage pool you want to remove is not being used, select the radio button.
Select Remove.
Select OK.
