View and edit group details
When you view the details for a group, you can change the group's display name, permissions, policies, and the users that belong to the group.
You must be signed in to the Tenant Manager using a supported web browser.
You must belong to a user group that has the Root Access permission.
Select ACCESS MANAGEMENT > Groups.
Select the name of the group whose details you want to view or edit.
Alternatively, you can select Actions > View group details.
The group details page appears. The following example shows the S3 group details page.
Make changes to the group settings as needed.
To ensure your changes are saved, select Save changes after you make changes in each section. When your changes are saved, a confirmation message appears in the upper right corner of the page. -
Optionally, select the display name or edit icon
to update the display name.You cannot change a group's unique name. You cannot edit the display name for a federated group.
Optionally, update the permissions.
For group policy, make the appropriate changes for your S3 or Swift tenant.
If you are editing a group for an S3 tenant, optionally select a different S3 group policy. If you select a custom S3 policy, update the JSON string as required.
If you are editing a group for a Swift tenant, optionally select or unselect the Swift Administrator check box.
For more information about the Swift Administrator permission, see the instructions for creating groups for a Swift tenant.
Optionally, add or remove users.
Confirm that you have selected Save changes for each section you changed.
Changes might take up to 15 minutes to take effect because of caching.
