Obtain additional equipment and tools (SG6000)
Contributors netapp-perveilerk
Before installing the StorageGRID appliance, confirm you have all of the additional equipment and tools that you need.
You need the following additional equipment to install and configure the hardware:
  • Screwdrivers
    Two screwdrivers
    Phillips No. 2 screwdriver
    Medium flat-blade screwdriver
  • ESD wrist strap
    ESD wrist strap
  • Optical cables and SFP transceivers
    Optical cable and SFP+ transceiver
    You need one of the following options:
    • One to four TwinAx cables or optical cables for the 10/25-GbE ports you plan to use on the SG6000-CN controller
    • One to four SFP+ transceivers for the 10/25-GbE ports if you will use optical cables and 10-GbE link speed
    • One to four SFP28 transceivers for the 10/25-GbE ports if you will use optical cables and 25-GbE link speed
  • RJ-45 (Cat5/Cat5e/Cat6) Ethernet cables
    Ethernet cables
  • Service laptop
    Service laptop
    1-GbE (RJ-45) port
  • Optional tools
    Power drill and flashlight
    Power drill with Phillips head bit
    Flashlight
    Mechanized lift for 60-drive shelves
