StorageGRID
SG6000-CN: Install into cabinet or rack
Contributors netapp-perveilerk
You must install a set of rails for the SG6000-CN controller in your cabinet or rack, and then slide the controller onto the rails.
What you’ll need
  • You have reviewed the Safety Notices document included in the box, and understand the precautions for moving and installing hardware.
  • You have the instructions packaged with the rail kit.
  • You have installed the E2860 controller shelf and drives or the EF570 controller shelf.
Steps
  1. Carefully follow the instructions for the rail kit to install the rails in your cabinet or rack.
  2. On the two rails installed in the cabinet or rack, extend the movable parts of the rails until you hear a click.
    SG6000 Rails
  3. Insert the SG6000-CN controller into the rails.
  4. Slide the controller into the cabinet or rack.
    When you cannot move the controller any further, pull the blue latches on both sides of the chassis to slide the controller all the way in.
    SG6000 Sliding on Rails
    Note Do not attach the front bezel until after you power on the controller.
  5. Tighten the captive screws on the controller front panel to secure the controller in the rack.
    SG6060 rack retaining screws
