Configure AutoSupport
The AutoSupport tool collects data in a customer support bundle from the appliance and automatically sends the data to technical support. Configuring AutoSupport assists technical support with remote troubleshooting and problem analysis.
The AutoSupport feature must be enabled and activated on the appliance.
The AutoSupport feature is activated and deactivated globally on a storage management station.
The Storage Manager Event Monitor must be running on at least one machine with access to the appliance and, preferably, on no more than one machine.
All of the data is compressed into a single compressed archive file format (.7z) at the location you specify.
AutoSupport provides the following types of messages:
| Message types | Description |
Event messages |
Daily messages |
Weekly messages |
From the Enterprise Management Window in SANtricity Storage Manager, select the Devices tab, and then select Discovered Storage Arrays.
Select Tools > AutoSupport > Configuration.
Use SANtricity Storage Manager online help, if needed, to complete the task.
