StorageGRID
Expansion shelves do not appear in Appliance Installer
Contributors netapp-perveilerk netapp-pcelmer
If you have installed expansion shelves for the SG6060 or SG6060X and they do not appear in the StorageGRID Appliance Installer, you should verify that the shelves have been completely installed and powered on.
About this task
You can verify that the expansion shelves are connected to the appliance by viewing the following information in the StorageGRID Appliance Installer:
  • The Home page contains a message about expansion shelves.
    Expansion Shelves Msg
  • The Advanced > RAID Mode page indicates by number of drives whether or not the appliance includes expansion shelves. For example, in the following screen shot, two SSDs and 178 HDDs are shown. An SG6060 with two expansion shelves contains 180 total drives.
Number of Drives
If the StorageGRID Appliance Installer pages do not indicate that expansion shelves are present, follow this procedure.
Steps
  1. Verify that all required cables have been firmly connected.
  2. Verify that you have powered on the expansion shelves.
  3. If you need help resolving an issue, contact technical support.
