Delete S3 bucket
PDF of this doc site
Install and maintain appliance hardware
Install and upgrade software
Perform system administration
Monitor and maintain StorageGRID
Recover and maintain
Grid node recovery procedures
Creating your file...
You can use the Tenant Manager to delete one or more S3 buckets that are empty.
You must be signed in to the Tenant Manager using a supported web browser.
You must belong to a user group that has the Manage All Buckets or the Root Access permission. These permissions override the permissions settings in group or bucket policies. See Tenant management permissions.
The buckets you want to delete are empty.
These instructions describe how to delete an S3 bucket using the Tenant Manager. You can also delete S3 buckets using the Tenant Management API or the S3 REST API.
You cannot delete an S3 bucket if it contains objects or noncurrent object versions. For information about how S3 versioned objects are deleted, see the instructions for managing objects with information lifecycle management.
Select STORAGE (S3) > Buckets.
The Buckets page appears and shows all existing S3 buckets.
Select the check box for the empty bucket you want to delete. You can select more than one bucket at a time.
The Actions menu is enabled.
From the Actions menu, select Delete bucket (or Delete buckets if you have chosen more than one).
When the confirmation dialog box appears, select Yes to delete all of the buckets you have chosen.
StorageGRID confirms that each bucket is empty and then deletes each bucket. This operation might take a few minutes.
If a bucket is not empty, an error message appears. You must delete all objects before you can delete a bucket.
