Monitor node encryption in maintenance mode (SG100 and SG1000)
Contributors netapp-perveilerk netapp-lhalbert
If you enabled node encryption for the appliance during installation, you can monitor the node-encryption status of each appliance node, including the node-encryption state and key management server (KMS) details.
What you’ll need
Steps
  1. From the StorageGRID Appliance Installer, select Configure Hardware > Node Encryption.
    KMS clear configuration
    The Node Encryption page includes three sections:
    • Encryption Status shows whether node encryption is enabled or disabled for the appliance.
    • Key Management Server Details shows information about the KMS being used to encrypt the appliance. You can expand the server and client certificate sections to view certificate details and status.
    • Clear KMS Key disables node encryption for the appliance, removes the association between the appliance and the key management server that was configured for the StorageGRID site, and deletes all data from the appliance. You must clear the KMS key before you can install the appliance into another StorageGRID system.
      Important Clearing the KMS configuration deletes data from the appliance, rendering it permanently inaccessible. This data is not recoverable.
  2. When you are done checking node-encryption status, reboot the node. From the StorageGRID Appliance Installer, select Advanced > Reboot Controller, and then select one of these options:
    • Select Reboot into StorageGRID to reboot the controller with the node rejoining the grid. Select this option if you are done working in maintenance mode and are ready to return the node to normal operation.
    • Select Reboot into Maintenance Mode to reboot the controller with the node remaining in maintenance mode. (This option is available only when the controller is in maintenance mode.) Select this option if there are additional maintenance operations you need to perform on the node before it can rejoin the grid.
      Reboot controller in maintenance mode
      It can take up to 20 minutes for the appliance to reboot and rejoin the grid. To confirm that the reboot is complete and that the node has rejoined the grid, go back to the Grid Manager. The NODES page should display a normal status (no icon) for the appliance node, indicating that no alerts are active and the node is connected to the grid.
      Appliance node rejoined grid
Related information
Administer StorageGRID
