Obtain the required materials for a software upgrade
Before you begin the software upgrade, you must obtain all required materials so you can complete the upgrade successfully.
| Item | Notes |
StorageGRID upgrade files |
Download the StorageGRID upgrade files to your service laptop. |
Service laptop |
The service laptop must have:
Browser support typically changes for each StorageGRID release. Make sure your browser is compatible with the new StorageGRID version. |
Recovery Package ( |
Download the Recovery Package before upgrading, and save the file in a safe location. The Recovery Package file allows you to restore the system if a failure occurs. |
This file is included in the SAID package, which is part of the Recovery Package |
Provisioning passphrase |
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not listed in the |
Related documentation |
You must download one or more files, depending on where your nodes are installed.
All platforms:
.upgradefile
If any nodes are deployed on Linux hosts, you must also download an RPM or DEB archive, which you will install before you start the upgrade:
Red Hat Enterprise Linux or CentOS: An additional RPM file (
.zipor.tgz) -
Ubuntu or Debian: An additional DEB file (
.zipor.tgz)
Select the button for downloading the latest release, or select another version from the drop-down menu and select Go.
StorageGRID software versions have this format: 11.x.y. StorageGRID hotfixes have this format: 11.x.y.z.
Sign in with the username and password for your NetApp account.
If a Caution/MustRead statement appears, read it and select the check box.
This statement appears if there is a required hotfix for the release.
Read the End User License Agreement, select the check box, and then select Accept & Continue.
The downloads page for the version you selected appears. The page contains three columns:
Install StorageGRID
Upgrade StorageGRID
Support files for StorageGRID Appliances
In the Upgrade StorageGRID column, select and download the
.upgradearchive.Every platform requires the
.upgradearchive. -
If any nodes are deployed on Linux hosts, also download the RPM or DEB archive in either
.tgzor.zipformat. Select the.zipfile if you are running Windows on the service laptop.-
StorageGRID-Webscale-version-RPM-uniqueID.zip
StorageGRID-Webscale-version-RPM-uniqueID.tgz -
Ubuntu or Debian
StorageGRID-Webscale-version-DEB-uniqueID.zip
StorageGRID-Webscale-version-DEB-uniqueID.tgzNo additional files are required for the SG100 or SG1000.
The Recovery Package file allows you to restore the StorageGRID system if a failure occurs. Download the current Recovery Package file before making grid topology changes to the StorageGRID system or before upgrading software. Then, download a new copy of the Recovery Package after making grid topology changes or after upgrading software.
You must be signed in to the Grid Manager using a supported web browser.
You must have the provisioning passphrase.
You must have specific access permissions.
Select Maintenance > System > Recovery Package.
Enter the provisioning passphrase, and select Start Download.
The download starts immediately.
When the download completes:
Open the
.zipfile. -
Confirm it includes a
gpt-backupdirectory and an inner.zipfile. -
Extract the inner
.zipfile. -
Confirm you can open the
Passwords.txtfile.
Copy the downloaded Recovery Package file (
.zip) to two safe, secure, and separate locations.The Recovery Package file must be secured because it contains encryption keys and passwords that can be used to obtain data from the StorageGRID system.
