Obtain the required materials for a software upgrade
Before you begin the software upgrade, obtain all required materials.
| Item | Notes |
Service laptop |
The service laptop must have:
Browser support typically changes for each StorageGRID release. Make sure your browser is compatible with the new StorageGRID version. |
Provisioning passphrase |
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not listed in the |
Linux RPM or DEB archive |
If any nodes are deployed on Linux hosts, you must download and install the RPM or DEB package on all hosts before you start the upgrade. Important: Ensure that your operating system is upgraded to Linux kernel 4.15 or higher. |
StorageGRID documentation |
