OLST: System Detected Lost Object
This message is generated when the DDS service can't locate any copies of an object within the StorageGRID system.
| Code | Field | Description |
CBID  |
Content Block Identifier  |
The CBID of the lost object.  |
NOID  |
Node ID  |
If available, the last known direct or near-line location of the lost object. It is possible to have just the Node ID without a Volume ID if the volume information is not available.  |
PATH  |
S3 Bucket/Key or Swift Container/Object ID  |
If available, the S3 bucket name and S3 key name, or the Swift container name and Swift object identifier.  |
RSLT  |
Result  |
This field has the value NONE. RSLT is a mandatory message field, but is not relevant for this message. NONE is used rather than SUCS so that this message is not filtered.  |
UUID  |
Universally Unique ID  |
The identifier of the lost object within the StorageGRID system.  |
VOLI  |
Volume ID  |
If available, the Volume ID of the Storage Node or Archive Node for the last known location of the lost object.  |
