OLST: System Detected Lost Object
This message is generated when the DDS service can't locate any copies of an object within the StorageGRID system.
Code Field Description
CBID
Content Block Identifier
The CBID of the lost object.
NOID
Node ID
If available, the last known direct or near-line location of the lost object. It is possible to have just the Node ID without a Volume ID if the volume information is not available.
PATH
S3 Bucket/Key
If available, the S3 bucket name and S3 key name.
RSLT
Result
This field has the value NONE. RSLT is a mandatory message field, but is not relevant for this message. NONE is used rather than SUCS so that this message is not filtered.
UUID
Universally Unique ID
The identifier of the lost object within the StorageGRID system.
VOLI
Volume ID
If available, the Volume ID of the Storage Node for the last known location of the lost object.
