Use S3 Console
You can use S3 Console to view and manage the objects in an S3 bucket.
S3 Console allows you to:
Upload, download, rename, copy, move, and delete objects
View, revert, download, and delete object versions
Search for objects by prefix
Manage object tags
View object metadata
View, create, rename, copy, move, and delete folders
S3 Console provides an improved user experience for the most common cases. It is not designed to replace CLI or API operations in all situations. If using S3 Console results in operations taking too long (for example, minutes or hours), consider:
You are signed in to the Tenant Manager using a supported web browser.
If you want to manage objects, you belong to a user group that has the Root access permission. Alternatively, you belong to a user group that has the Use S3 Console tab permission and either the View all buckets permission or Manage all buckets permission. See Tenant management permissions.
An S3 Group or Bucket policy has been configured for the user. See Use bucket and group access policies.
You know the user's access key ID and secret access key. Optionally, you have a
.csvfile containing this information. See the instructions for creating access keys.
Select STORAGE > Buckets > bucket name.
Select the S3 Console tab.
Paste the access key ID and secret access key into the fields. Otherwise, select Upload access keys and select your
.csvfile. -
Select Sign in.
The table of bucket objects appears. You can manage objects as needed.
Search by prefix: The prefix search feature only searches for objects that begin with a specific word relative to the current folder. The search does not include objects that contain the word elsewhere. This rule also applies to objects within folders. For example, a search for
folder1/folder2/somefile-would return objects that are within thefolder1/folder2/folder and begin with the wordsomefile-. -
Drag and drop: You can drag and drop files from your computer's file manager to S3 Console. However, you cannot upload folders.
Operations on folders: When you move, copy, or rename a folder, all objects in the folder are updated one at a time, which might take time.
Permanent deletion when bucket versioning is disabled: When you overwrite or delete an object in a bucket with versioning disabled, the operation is permanent. See Change object versioning for a bucket.
