Deployment and maintenance logs
You can use the deployment and maintenance logs to troubleshoot issues.
File name Notes Found on
/var/local/log/install.log
Created during software installation. Contains a record of the installation events.
All nodes
/var/local/log/expansion-progress.log
Created during expansion operations. Contains a record of the expansion events.
Storage Nodes
/var/local/log/pa-move.log
Created while running the pa-move.sh script.
Primary Admin Node
/var/local/log/pa-move-new_pa.log
Primary Admin Node
/var/local/log/pa-move-old_pa.log
Primary Admin Node
/var/local/log/gdu-server.log
Created by the GDU service. Contains events related to provisioning and maintenance procedures managed by the primary Admin Node.
Primary Admin Node
/var/local/log/send_admin_hw.log
Created during installation. Contains debugging information related to a node's communications with the primary Admin Node.
All nodes
/var/local/log/upgrade.log
Created during software upgrade. Contains a record of the software update events.
All nodes
