Download and extract the StorageGRID installation files
You must download the StorageGRID installation archives and extract the files..
Go to the NetApp Downloads page for StorageGRID.
Select the button for downloading the latest release, or select another version from the drop-down menu and select Go.
Sign in with the username and password for your NetApp account.
If a Caution/MustRead statement appears, read it and select the checkbox.
You must apply any required hotfixes after you install the StorageGRID release. For more information, see the hotfix procedure in the recovery and maintenance instructions -
Read the End User License Agreement, select the checkbox, and then select Accept & Continue.
In the Install StorageGRID column, select the .tgz or .zip file for VMware.
Use the .zipfile if you are running Windows on the service laptop. -
Save and extract the archive file.
Choose the files you need from the following list.
The files you need depend on your planned grid topology and how you will deploy your StorageGRID system.
The paths listed in the table are relative to the top-level directory installed by the extracted installation archive. |
| Path and file name | Description |
A text file that describes all of the files contained in the StorageGRID download file. |
A free license that does not provide any support entitlement for the product. |
The virtual machine disk file that is used as a template for creating grid node virtual machines. |
The Open Virtualization Format template file ( |
The template file ( |
Deployment scripting tool |
Description |
A Bash shell script used to automate the deployment of virtual grid nodes. |
An example configuration file for use with the |
A Python script used to automate the configuration of a StorageGRID system. |
A Python script used to automate the configuration of StorageGRID appliances. |
An example Python script that you can use to sign in to the Grid Management API when single sign-on (SSO) is enabled. You can also use this script for Ping Federate. |
A blank configuration file for use with the |
An example Python script that you can use to sign in to the Grid Management API when single sign-on (SSO) is enabled using Active Directory or Ping Federate. |
A helper script called by the companion |
API schemas for StorageGRID. Note: Before you perform an upgrade, you can use these schemas to confirm that any code you have written to use StorageGRID management APIs will be compatible with the new StorageGRID release if you don't have a non-production StorageGRID environment for upgrade compatibility testing. |
