What is an Archive Node?
Support for Archive Nodes is deprecated and will be removed in a future release.
Support for Archive Nodes is deprecated and will be removed in a future release. Moving objects from an Archive Node to an external archival storage system through the S3 API has been replaced by ILM Cloud Storage Pools, which offer more functionality. The Cloud Tiering - Simple Storage Service (S3) option is also deprecated. If you are currently using an Archive Node with this option, migrate your objects to a Cloud Storage Pool instead. Additionally, you should remove Archive Nodes from the active ILM policies in StorageGRID 11.7 or earlier. Removing object data stored on Archive Nodes will simplify future upgrades. See Working with ILM rules and ILM policies. |
Primary services for Archive Nodes
The following table shows the primary services for Archive Nodes; however, this table does not list all node services.
| Service | Key function |
Archive (ARC) |
Communicates with a Tivoli Storage Manager (TSM) external tape storage system. |
Server Status Monitor (SSM) |
Monitors the operating system and underlying hardware. |
