Changes to the Tenant Management API
StorageGRID 11.8 uses version 4 of the Tenant Management API. Version 4 deprecates version 3; however, versions 1, 2, and 3 are still supported.
You can continue to use deprecated versions of the Tenant Management API with StorageGRID 11.8; however, support for these versions of the API will be removed in a future release of StorageGRID. After upgrading to StorageGRID 11.8, the deprecated APIs can be deactivated using the PUT /grid/config/management API.
To learn more, go to Understand the Tenant Management API.
New endpoints for ILM policy tags
You can use the /org/ilm-policy-tags and /org/containers/{bucketName}/ilm-policy-tags API endpoints to perform operations related to ILM policy tags.
