SDEL: S3 DELETE
When an S3 client issues a DELETE transaction, a request is made to remove the specified object or bucket, or to remove a bucket/object subresource. This message is issued by the server if the transaction is successful.
| Code | Field | Description |
CBID  |
Content Block Identifier  |
The unique identifier of the content block requested. If the CBID is unknown, this field is set to 0. Operations on buckets don't include this field.  |
CNCH  |
Consistency Control Header  |
The value of the Consistency-Control HTTP request header, if present in the request.  |
CNID  |
Connection Identifier  |
The unique system identifier for the TCP/IP connection.  |
CSIZ  |
Content Size  |
The size of the deleted object in bytes. Operations on buckets don't include this field.  |
DMRK  |
Delete Marker Version ID  |
The version ID of the delete marker created when deleting an object from a versioned bucket. Operations on buckets don't include this field.  |
GFID  |
Grid Federation Connection ID  |
The connection ID of the grid federation connection associated with a cross-grid replication delete request. Only included in audit logs on the destination grid.  |
GFSA  |
Grid Federation Source Account ID  |
The account ID of the tenant on the source grid for a cross-grid replication delete request. Only included in audit logs on the destination grid.  |
HTRH  |
HTTP Request Header  |
List of logged HTTP request header names and values as selected during configuration.
MTME  |
Last Modified Time  |
The Unix timestamp, in microseconds, indicating when the object was last modified.  |
RSLT  |
Result Code  |
Result of the DELETE transaction. Result is always: SUCS: Successful  |
S3AI  |
S3 tenant account ID (request sender)  |
The tenant account ID of the user who sent the request. An empty value indicates anonymous access.  |
S3AK  |
S3 Access Key ID (request sender)  |
The hashed S3 access key ID for the user that sent the request. An empty value indicates anonymous access.  |
S3BK  |
S3 Bucket  |
The S3 bucket name.  |
S3KY  |
S3 Key  |
The S3 key name, not including the bucket name. Operations on buckets don't include this field.  |
S3SR  |
S3 Subresource  |
The bucket or object subresource being operated on, if applicable.  |
SACC  |
S3 tenant account name (request sender)  |
The name of the tenant account for the user who sent the request. Empty for anonymous requests.  |
SAIP  |
IP address (request sender)  |
The IP address of the client application that made the request.  |
SBAC  |
S3 tenant account name (bucket owner)  |
The tenant account name for the bucket owner. Used to identify cross-account or anonymous access.  |
SBAI  |
S3 tenant account ID (bucket owner)  |
The tenant account ID of the owner of the target bucket. Used to identify cross-account or anonymous access.  |
SGRP  |
Site (Group)  |
If present, the object was deleted at the site specified, which is not the site where the object was ingested.  |
SUSR  |
S3 User URN (request sender)  |
The tenant account ID and the user name of the user making the request. The user can either be a local user or an LDAP user. For example:  Empty for anonymous requests.  |
TIME  |
Time  |
Total processing time for the request in microseconds.  |
TLIP  |
Trusted Load Balancer IP Address  |
If the request was routed by a trusted Layer 7 load balancer, the IP address of the load balancer.  |
UUDM  |
Universally Unique Identifier for a Delete Marker  |
The identifier of a delete marker. Audit log messages specify either UUDM or UUID, where UUDM indicates a delete marker created as a result of an object delete request, and UUID indicates an object.  |
UUID  |
Universally Unique Identifier  |
The identifier of the object within the StorageGRID system.  |
VSID  |
Version ID  |
The version ID of the specific version of an object that was deleted. Operations on buckets and objects in unversioned buckets don't include this field.  |
