The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
SYSU: Node Start
PDF of this doc site
Install, upgrade, and hotfix
Configure and manage
Creating your file...
Your file is ready
When a service is restarted, this message is generated to indicate if the previous shutdown was clean (commanded) or disorderly (unexpected).
Code | Field | Description |
RSLT |
Clean Shutdown |
The nature of the shutdown: SUCS: System was cleanly shut down. DSDN: System was not cleanly shut down. VRGN: System was started for the first time after server installation (or re-installation). |
The message does not indicate if the host server was started, only the reporting service. This message can be used to:
Detect discontinuity in the audit trail.
Determine if a service is failing during operation (as the distributed nature of the StorageGRID system can mask these failures). Server Manager restarts a failed service automatically.
