SYSU: Node Start
PDF of this doc site
Install and upgrade software
Install and maintain hardware
SG5700 storage appliances
SG5600 storage appliances
Configure and manage
Administer StorageGRID
Use StorageGRID
Monitor and troubleshoot
Monitor a StorageGRID system
Creating your file...
Your file is ready
When a service is restarted, this message is generated to indicate if the previous shutdown was clean (commanded) or disorderly (unexpected).
Code | Field | Description |
RSLT |
Clean Shutdown |
The nature of the shutdown: SUCS: System was cleanly shut down. DSDN: System was not cleanly shut down. VRGN: System was started for the first time after server installation (or re-installation). |
The message does not indicate if the host server was started, only the reporting service. This message can be used to:
Detect discontinuity in the audit trail.
Determine if a service is failing during operation (as the distributed nature of the StorageGRID system can mask these failures). Server Manager restarts a failed service automatically.
