      Network port reference
You must ensure the network infrastructure can provide internal and external communication between nodes within the grid and to external clients and services. You might need access across internal and external firewalls, switching systems, and routing systems.
Use the details provided for Internal grid node communications and External communications to determine how to configure each required port.
