Storage Node configuration settings
Each Storage Node uses several configuration settings and counters. You might need to view the current settings or reset counters to clear alarms (legacy system).
Except when specifically instructed in documentation, you should consult with technical support before modifying any Storage Node configuration settings. As required, you can reset event counters to clear legacy alarms. |
Follow these steps to access a Storage Node's configuration settings and counters.
Select SUPPORT > Tools > Grid topology.
Select site > Storage Node.
Expand the Storage Node and select the service or component.
Select the Configuration tab.
The following tables summarize Storage Node configuration settings.
LDR
| Attribute Name | Code | Description |
HTTP State |
HSTE |
The current state of HTTP for S3, Swift, and other internal StorageGRID traffic:
Auto-Start HTTP |
HTAS |
LDR > Data Store
Reset Lost Objects Count |
RCOR |
Reset the counter for the number of lost objects on this service. |
LDR > Storage
Storage State — Desired |
SSDS |
A user-configurable setting for the desired state of the storage component. The LDR service reads this value and attempts to match the status indicated by this attribute. The value is persistent across restarts. For example, you can use this setting to force storage to become read-only even when there is ample available storage space. This can be useful for troubleshooting. The attribute can take one of the following values:
Health Check Timeout |
SHCT |
The time limit in seconds within which a health check test must complete in order for a storage volume to be considered healthy. Only change this value when directed to do so by Support. |
LDR > Verification
Reset Missing Objects Count |
VCMI |
Resets the count of Missing Objects Detected (OMIS). Use only after object existence check completes. Missing replicated object data is restored automatically by the StorageGRID system. |
Verification Rate |
VPRI |
Set the rate at which background verification takes place. See information about configuring the background verification rate. |
Reset Corrupt Objects Count |
VCCR |
Reset the counter for corrupt replicated object data found during background verification. This option can be used to clear the Corrupt Objects Detected (OCOR) alarm condition. |
Delete Quarantined Objects |
OQRT |
Delete corrupt objects from the quarantine directory, reset the count of quarantined objects to zero, and clear the Quarantined Objects Detected (OQRT) alarm. This option is used after corrupt objects have been automatically restored by the StorageGRID system. If a Lost Objects alarm is triggered, technical support might want to access the quarantined objects. In some cases, quarantined objects might be useful for data recovery or for debugging the underlying issues that caused the corrupt object copies. |
LDR > Erasure Coding
Reset Writes Failure Count |
RSWF |
Reset the counter for write failures of erasure-coded object data to the Storage Node. |
Reset Reads Failure Count |
RSRF |
Reset the counter for read failures of erasure-coded object data from the Storage Node. |
Reset Deletes Failure Count |
RSDF |
Reset the counter for delete failures of erasure-coded object data from the Storage Node. |
Reset Corrupt Copies Detected Count |
RSCC |
Reset the counter for the number of corrupt copies of erasure-coded object data on the Storage Node. |
Reset Corrupt Fragments Detected Count |
RSCD |
Reset the counter for corrupt fragments of erasure-coded object data on the Storage Node. |
Reset Missing Fragments Detected Count |
RSMD |
Reset the counter for missing fragments of erasure-coded object data on the Storage Node. Use only after object existence check completes. |
LDR > Replication
Reset Inbound Replication Failure Count |
RICR |
Reset the counter for inbound replication failures. This can be used to clear the RIRF (Inbound Replication — Failed) alarm. |
Reset Outbound Replication Failure Count |
ROCR |
Reset the counter for outbound replication failures. This can be used to clear the RORF (Outbound Replications — Failed) alarm. |
Disable Inbound Replication |
DSIR |
Select to disable inbound replication as part of a maintenance or testing procedure. Leave unchecked during normal operation. When inbound replication is disabled, objects can be retrieved from the Storage Node for copying to other locations in the StorageGRID system, but objects can't be copied to this Storage Node from other locations: the LDR service is read-only. |
Disable Outbound Replication |
DSOR |
Select to disable outbound replication (including content requests for HTTP retrievals) as part of a maintenance or testing procedure. Leave unchecked during normal operation. When outbound replication is disabled, objects can be copied to this Storage Node, but objects can't be retrieved from the Storage Node to be copied to other locations in the StorageGRID system. The LDR service is write-only. |
