How object retention is determined
StorageGRID provides options for both grid administrators and individual tenant users to specify how long to store objects. In general, any retention instructions provided by a tenant user take precedence over the retention instructions provided by the grid administrator.
How tenant users control object retention
Tenant users have three primary ways to control how long their objects are stored in StorageGRID:
If the global S3 Object Lock setting is enabled for the grid, S3 tenant users can create buckets with S3 Object Lock enabled and then use the S3 REST API to specify retain-until-date and legal hold settings for each object version added to that bucket.
An object version that is under a legal hold can't be deleted by any method.
Before an object version's retain-until-date is reached, that version can't be deleted by any method.
Objects in buckets with S3 Object Lock enabled are retained by ILM "forever." However, after its retain-until-date is reached, an object version can be deleted by a client request or the expiration of the bucket lifecycle. See Manage objects with S3 Object Lock.
S3 tenant users can add a lifecycle configuration to their buckets that specifies an Expiration action. If a bucket lifecycle exists, StorageGRID stores an object until the date or number of days specified in the Expiration action are met, unless the client deletes the object first. See Create S3 lifecycle configuration.
An S3 or Swift client can issue a delete object request. StorageGRID always prioritizes client delete requests over S3 bucket lifecycle or ILM when determining whether to delete or retain an object.
How grid administrators control object retention
Grid administrators use ILM placement instructions to control how long objects are stored. When objects are matched by an ILM rule, StorageGRID stores those objects until the last time period in the ILM rule has elapsed. Objects are retained indefinitely if "forever" is specified for the placement instructions.
Regardless of who controls how long objects are retained, ILM settings control what types of object copies (replicated or erasure-coded) are stored and where the copies are located (Storage Nodes, Cloud Storage Pools, or Archive Nodes).
How S3 bucket lifecycle and ILM interact
When an S3 bucket lifecycle is configured, the lifecycle expiration actions override the ILM policy for objects that match the lifecycle filter. As a result, an object might be retained on the grid even after any ILM instructions for placing the object have lapsed.
Examples for object retention
To better understand the interactions between S3 Object Lock, bucket lifecycle settings, client delete requests, and ILM, consider the following examples.
Example 1: S3 bucket lifecycle keeps objects longer than ILM
- ILM
Store two copies for 1 year (365 days)
- Bucket lifecycle
Expire objects in 2 years (730 days)
- Result
StorageGRID stores the object for 730 days. StorageGRID uses the bucket lifecycle settings to determine whether to delete or retain an object.
If the bucket lifecycle specifies that objects should be kept longer than specified by ILM, StorageGRID continues to use the ILM placement instructions when determining the number and type of copies to store. In this example, two copies of the object will continue to be stored in StorageGRID from days 366 to 730. |
Example 2: S3 bucket lifecycle expires objects before ILM
- ILM
Store two copies for 2 years (730 days)
- Bucket lifecycle
Expire objects in 1 year (365 days)
- Result
StorageGRID deletes both copies of the object after day 365.
Example 3: Client delete overrides bucket lifecycle and ILM
- ILM
Store two copies on Storage Nodes "forever"
- Bucket lifecycle
- Client delete request
Issued on day 400
- Result
StorageGRID deletes both copies of the object on day 400 in response to the client delete request.
Example 4: S3 Object Lock overrides client delete request
- S3 Object Lock
Retain-until-date for an object version is 2026-03-31. A legal hold is not in effect.
- Compliant ILM rule
Issued on 2024-03-31
- Result
StorageGRID will not delete the object version because the retain-until-date is still 2 years away.
