Log files reference: Overview
StorageGRID provides logs that are used to capture events, diagnostic messages, and error conditions. You might be asked to collect log files and forward them to technical support to assist with troubleshooting.
The logs are categorized as follows:
Note The details provided for each log type are for reference only. The logs are intended for advanced troubleshooting by technical support. Advanced techniques that involve reconstructing the problem history using the audit logs and the application log files are beyond the scope of these instructions.
Access the logs
To access the logs, you can collect log files and system data from one or more nodes as a single log file archive. Or, if the primary Admin Node is unavailable or unable to reach a specific node, you can access individual log files for each grid node as follows:
  1. Enter the following command: ssh admin@grid_node_IP
  2. Enter the password listed in the Passwords.txt file.
  3. Enter the following command to switch to root: su -
  4. Enter the password listed in the Passwords.txt file.
Log file categories
The StorageGRID log file archive contains the logs described for each category and additional files that contain metrics and debug command output.
Archive location Description
audit
Audit messages generated during normal system operation.
base-os-logs
Base operating system information, including StorageGRID image versions.
bundles
Global configuration information (bundles).
cassandra
Cassandra database information and Reaper repair logs.
ec
VCSs information about the current node and EC group information by profile ID.
grid
General grid logs including debug (bycast.log) and servermanager logs.
grid.xml
Grid configuration file shared across all nodes.
hagroups
High availability groups metrics and logs.
install
Gdu-server and install logs.
lumberjack.log
Debug messages related to log collection.
Lambda-arbitrator
Logs related to the S3 Select proxy request.
Metrics
Service logs for Grafana, Jaeger, node exporter, and Prometheus.
miscd
Miscd access and error logs.
mysql
The mariaDB database configuration and related logs.
net
Logs generated by networking-related scripts and the Dynip service.
nginx
Load balancer and grid federation configuration files and logs. Also includes Grid Manager and Tenant Manager traffic logs.
nginx-gw
ntp
NTP configuration file and logs.
os
Node and grid state file, including services pid.
other
Log files under /var/local/log that aren't collected in other folders.
perf
Peformance information for CPU, networking, and disk I/O.
prometheus-data
Current Prometheus metrics, if the log collection includes Prometheus data.
provisioning
Logs related to grid provisioning process.
raft
Logs from Raft cluster used in platform services.
ssh
Logs related to SSH configuration and service.
snmp
SNMP agent configuration and alarm allow/deny lists used for sending SNMP notifications.
sockets-data
Sockets data for network debug.
system-commands.txt
Output of StorageGRID container commands. Contains system information, such as networking and disk usage.
