Required information and materials
Before you install StorageGRID, gather and prepare the required information and materials.
- Network plan
Which networks you intend to attach to each StorageGRID node. StorageGRID supports multiple networks for traffic separation, security, and administrative convenience.
See the StorageGRID Networking guidelines.
- Network information
Unless you are using DHCP, IP addresses to assign to each grid node and the IP addresses of the DNS and NTP servers.
- Servers for grid nodes
Identify a set of servers (physical, virtual, or both) that, in aggregate, provide sufficient resources to support the number and type of StorageGRID nodes you plan to deploy.
If your StorageGRID installation will not use StorageGRID appliance (hardware) Storage Nodes, you must use hardware RAID storage with battery-backed write cache (BBWC). StorageGRID does not support the use of virtual storage area networks (vSANs), software RAID, or no RAID protection. - Related information
Required materials
- NetApp StorageGRID license
You must have a valid, digitally signed NetApp license.
A non-production license, which can be used for testing and proof of concept grids, is included in the StorageGRID installation archive. |
- StorageGRID installation archive
Download the StorageGRID installation archive and extract the files.
- Service laptop
The StorageGRID system is installed through a service laptop.
The service laptop must have:
Network port
SSH client (for example, PuTTY)
- StorageGRID documentation
