Compare alerts and alarms
There are several similarities between the alert system and the legacy alarm system, but the alert system offers significant benefits and is easier to use.
Refer to the following table to learn how to perform similar operations.
| Alerts | Alarms (legacy system) | |
How do I see which alerts or alarms are active?  |
Select SUPPORT > Alarms (legacy) > Current alarms.  |
What causes an alert or an alarm to be triggered?  |
Alerts are triggered when a Prometheus expression in an alert rule evaluates as true for the specific trigger condition and duration.  |
Alarms are triggered when a StorageGRID attribute reaches a threshold value.  |
If an alert or alarm is triggered, how do I resolve the underlying problem?  |
The recommended actions for an alert are included in email notifications and are available from the Alerts pages in the Grid Manager. As required, additional information is provided in the StorageGRID documentation.  |
You can learn about an alarm by selecting the attribute name, or you can search for an alarm code in the StorageGRID documentation.  |
Where can I see a list of alerts or alarms that have been resolved?  |
Select ALERTS > Resolved.  |
Select SUPPORT > Alarms (legacy) > Historical alarms.  |
Where do I manage the settings?  |
Select ALERTS > Rules.  |
Select SUPPORT. Then, use the options in the Alarms (legacy) section of the menu.  |
What user group permissions do I need?  |
How do I manage email notifications?  |
Select ALERTS > Email setup. Note: Because alarms and alerts are independent systems, the email setup used for alarm and AutoSupport notifications is not used for alert notifications. However, you can use the same mail server for all notifications.  |
Select SUPPORT > Alarms (legacy) > Legacy email setup.  |
How do I manage SNMP notifications?  |
Select CONFIGURATION > Monitoring > SNMP agent.  |
Not supported  |
How do I control who receives notifications?  |
Which Admin Nodes send notifications?  |
A single Admin Node (the preferred sender).  |
How do I suppress some notifications?  |
 Note: If you have enabled the SNMP agent, silences also suppress SNMP traps and informs.  |
How do I suppress all notifications?  |
Select ALERTS > Silences.Then, select All rules. Note: If you have enabled the SNMP agent, silences also suppress SNMP traps and informs.  |
Not supported  |
How do I customize the conditions and triggers?  |
How do I disable an individual alert or alarm?  |
