Use Experimental S3 Console
You can use S3 Console to view the objects in an S3 bucket.
You can also use S3 Console to do the following:
Add and delete objects, object versions, and folders
Rename objects
Move and copy objects between buckets and folders
Manage object tags
View object metadata
Download objects
S3 Console has not been fully tested and is marked as “experimental.” It is not intended for bulk management of objects or for use in a production environment. Tenants should only use S3 Console when performing functions for a small number of objects, such as when uploading objects to simulate a new ILM policy, troubleshooting ingest issues, or using proof-of-concept or non-production grids. |
You are signed in to the Tenant Manager using a supported web browser.
You have the Manage Your Own S3 Credentials permission.
You have created a bucket.
You know the user's access key ID and secret access key. Optionally, you have a
.csvfile containing this information. See the instructions for creating access keys.
Select Buckets.
Select
. You can also access this link from the bucket details page. -
On the Experimental S3 Console sign-in page, paste the access key ID and secret access key into the fields. Otherwise, select Upload access keys and select your
.csvfile. -
Select Sign in.
Manage objects as needed.
