View the Dashboard
When you first sign in to the Grid Manager, you can use the Dashboard to monitor system activities at a glance. The Dashboard includes information about system health, usage metrics, and operational trends and charts.
Search field
The Search field in the header bar allows you to quickly navigate to a specific page or sidebar entry within the Grid Manager. For example, you can enter key to access the Key Management Server page.
Health panel
| Description | View additional details | Learn more |
Summarizes the system's health. A green checkmark means that there are no current alerts and all grid nodes are connected. Any other icon means that there is at least one current alert or disconnected node. |
You might see one or more of the following links:
Available Storage panel
Displays the available and used storage capacity in the entire grid, not including archival media. The Overall chart presents grid-wide totals. If this is a multi-site grid, additional charts appear for each data center site. You can use this information to compare the used storage with the available storage. If you have a multi-site grid, you can determine which site is consuming more storage. |
Information Lifecycle Management (ILM) panel
Displays current ILM operations and ILM queues for your system. You can use this information to monitor your system's workload.
Protocol Operations panel
Displays the number of protocol-specific operations (S3 and Swift) performed by your system. You can use this information to monitor your system's workloads and efficiencies. Protocol rates are averaged over the last two minutes. |
