VLST: User Initiated Volume Lost
This message is issued whenever the /proc/CMSI/Volume_Lost command is run.
| Code | Field | Description |
VOLL |
Volume Identifier Lower |
The lower end of the affected volume range or a single volume. |
VOLU |
Volume Identifier Upper |
The upper end of the affected volume range. Equal to VOLL if a single volume. |
NOID |
Source Node ID |
The node ID on which the locations were lost. |
LTYP |
Location Type |
'CLDI' (Online) or 'CLNL' (Nearline). If not specified, defaults to 'CLDI'. |
RSLT |
Result |
Always 'NONE'. RSLT is a mandatory message field, but is not relevant for this message. 'NONE' is used rather than 'SUCS' so that this message is not filtered. |
