Replace Archive Node
PDF of this doc site
Install and maintain appliance hardware
Install and upgrade software
Perform system administration
Monitor and maintain StorageGRID
Recover and maintain
Grid node recovery procedures
Creating your file...
Your file is ready
To recover an Archive Node, you must first replace the node.
You must select the node replacement procedure for your platform. The steps to replace a node are the same for all types of grid nodes.
Platform | Procedure |
VMware |
Linux |
OpenStack |
NetApp-provided virtual machine disk files and scripts for OpenStack are no longer supported for recovery operations. If you need to recover a node running in an OpenStack deployment, download the files for your Linux operating system. Then, follow the procedure for replacing a Linux node. |
