      Replace Archive Node
To recover an Archive Node, you must first replace the node.
You must select the node replacement procedure for your platform. The steps to replace a node are the same for all types of grid nodes.
| Platform | Procedure |
VMware  |
Linux  |
OpenStack  |
NetApp-provided virtual machine disk files and scripts for OpenStack are no longer supported for recovery operations. If you need to recover a node running in an OpenStack deployment, download the files for your Linux operating system. Then, follow the procedure for replacing a Linux node.  |
