Set up hardware: Overview
PDF of this doc site
Install and upgrade
Configure and manage
Maintain
Recover nodes and maintain your grid
Creating your file...
After applying power to the appliance, you configure the network connections that will be used by StorageGRID.
Configure required network connections
For all appliances, you perform several tasks to configure required network connections such as:
Access the Appliance Installer
Configure network links
Verify port-level network connections
Additional configuration that might be required
Depending upon which appliance types you are configuring, additional hardware configuration might be required.
SANtricity System Manager
For SG6000 and SG5700, you configure SANtricity System Manager. The SANtricity software is used to monitor the hardware for these appliances.
BMC interface
The following appliances have a BMC interface that must be configured:
SGF6112
SG6000
SG1000
SG100
Optional configuration
Storage appliances
Configure SANtricity System Manager (SG6000 and SG5700) the software you will use to monitor the hardware
Change the RAID mode
Services appliances
Access the BMC interface for the SG100 and SG1000 and the SG6000-CN controller
