Apply hotfixes or upgrade software if necessary
PDF of this doc site
Install and upgrade
Configure and manage
Maintain
Recover nodes and maintain your grid
Creating your file...
If a hotfix or a new version of StorageGRID software is available, you should assess whether the update is appropriate for your system, and install it if required.
StorageGRID hotfixes contain software changes that are made available outside of a feature or patch release. The same changes are included in a future release.
Select the down arrow for the Type/Select Version field to see a list of the updates that are available to download:
StorageGRID software versions: 11.x.y
StorageGRID hotfixes: 11.x.y.z
Review the changes that are included in the update:
Select the version from the menu, and select Go.
Sign in using the username and password for your NetApp account.
Read and accept the End User License Agreement.
The downloads page for the version you selected appears.
Learn about the changes included in the software version or hotfix.
For a new software version, see What's new for the version you selected.
For a hotfix, download the README file for a summary of the changes included in the hotfix.
If you decide a software update is required, locate the instructions before proceeding.
For a new software version, carefully follow the instructions for upgrading software.
For a hotfix, see the StorageGRID hotfix procedure.
